whats better
Discussion in 'Civic and CRX - EF' started by 89 hatch, Aug 7, 2007.
  1. 89 hatch
    89 hatch New Member
    fl
    whats better dry or wet nitros
  2. eg6sir
    well, i like mine wet.. it kinda hurts when its dry .. :ph34r:
  3. quadboy2002
    quadboy2002 fed-town racer
    washington
    wet shot is better if u use dry its bad on your motor but so is wet but with a dry shot its just a matter of time on ur motor blowing up
  4. 89 hatch
    89 hatch New Member
    fl
    now dont quote me but I thought that dry was safer if you adjust your fuel. I heard that the only problem with dry is people dont adjust there fuel and run lean till there motor goes
  5. '91rex
    '91rex New Member
    :laughbounce2: nice one..
  6. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Wet vs. dry depends on your fuel management system. In general, the wet is easier since fuel is added along with the nitrous, so you don't have to worry about adjusting the ECU. On the other hand, a dry system will work just as well as a wet system, if tuned properly(adjusting the ECU to compensate for fuel).
