Whats The Difference????
Discussion in 'ECU's, Electronics, and Tuning' started by boston-sol77, Apr 30, 2008.
  1. boston-sol77
    boston-sol77 New Member
    i wanted to know whats the difference between a d series harness and a b series engine harness. i cant tell the difference. and is there a way to id what kind of harness you have??? cuz i have one kicking around and i need one for my swap but i dont know what kind of harness it is:confused:...... thanks
  2. OKCZombie
    OKCZombie Banned
    not much difference length and some placement of plugs and wires - I can't tell by looks most of the time
  3. boston-sol77
    some one told me its the knock sensor, that sohc motors dont have one. is that the difference??
  4. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    Depends on the b-series engine harness. They arent all exact in lengths. The gs-r harness' go to the shock tower, which is why people use them when they do swaps in EG chassis'. Depends if the engine the harness came off of was obd1/obd2, it will have different injector plugs and so forth.
