the only possible problem with that setup is the stock offset is +38, changing to a +35 naturally moves the tire 3mm inward. and switching from the stock suspention to full coils you are going to lose 8-10mm of room on the inside for tires.
if any of you are avid SCC readers, the check back to the "budget bad boys" issue
that dude ran apex WS coilevers with 16X7.5 Kosei's and only 225/50 rubber. and with the +32 offset he ran, could barely squeeze -.5 degrees of neg camber up front.
also dont forget the purpose of what you want to accomplish with you car, altering the offset of your wheel will also affect your slip angle, too big of a change in the front will KILL your steering feel. also i recommend NOT staggering, granted it does look cool, but ultimately all is does is mess the balance, and aside from the lovely understeer from the factory, it is an exceptionally well balanced car. and even though you can run big rims, remember, bigger rim = more weight = higher rotational mass = slower times.
AND if you are planning to drift with this car, you are going to want an even narrower tire, i mean really stretch them to prevent any sidewall movement, like 205's on an 8" wheel stretch.
now that im done blabbering like i actually know something ill give my recommendation
15x7 +35 on all 4 corners with either a 205/55 or 225/50 tire. this will minimize slip angle, retain close to factory feel, and keep the car balanced, as well as reduce rotational mass. especially if you go with a light tire like the new Azenis.
