Which gauge cluster for 89 DX?
Discussion in 'Civic and CRX - EF' started by hunterhound, Nov 18, 2008.
  1. hunterhound
    hunterhound New Member
    I want to get a gauge cluster with a tach for my 89 dx 5 spd standard. Which clusters can I get that will make this the easiest possible...by easy I mean pull one out and plug one in with no modificiations?
  2. austin20110
    austin20110 New Member
    Northern Va
    None
  3. D16SiHatch
    D16SiHatch New Member
    wrong
    there are a few 88-89 clusters which are direct swap replacements which will give you a tach. you could even use a 90-91 si cluster, you just have to switch some wires around.
  4. austin20110
    Northern Va
    did you read his post!
    NO MOD'S
  5. slowlx
    slowlx Junior Member
    Hudson, FL.
    88-89 SI, LX, HF. I have had a HF cluster in my car for a day then I swaped in a LX cluster, so I know they are a direct swap. This was in a 88 DX. The SI and LX clusters look the same but the HF has a lower redline and a shift light.
  6. D16SiHatch
    i was unaware moving wires around was all that big of a "mod" ....
    not to mention you were wrong chief. i clearly gave him options with 88-89 clusters that don't require any mods ; )
  7. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    That makes changing spark plugs and wires an EXTREME MOD!
