Which Performance Upgrade?
Discussion in 'Engine Building' started by jasondw, Apr 9, 2006.
  1. jasondw
    jasondw Junior Member
    Hello everyone. New to this board. Here is my story, I originally bought my '95 Honda Civic DX about 6 years ago (probably more), with plans to fix it up. I got off track and got into motorcycles instead. Now that I'm well into motorcycles and all that I want to start fixing up the civic again. Just wondering what performance upgrades would be the best bang for the buck. Don't have a lot of money to spend right now so I'm just looking for some upgrades I can do for fairly inexpensive to get better performance out of my civic. I plan to do an engine swap with probably a B18C1, once I have the money for that.
    Well, any help would be appreciated. I've done quite a bit of searching on the web but wanted to hear what others have to say on what the best inexpensive performance upgrades are.
    Thanks in advance.
  2. trappd-in-859
    trappd-in-859 New Member
    burlington, ky
    You could possibly use NO2 if your engine isnt too old. But, other than that, basic bolt-ons should suffice.
    Cat-back exhaust, CAI, and a header.
    If you have some mechanical know how, you could swap the dx head for a ex or si head, or even the engine entirely.
    Hope some of this helps.
  3. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    if you plan on doing an engine swap you might as well upgrade other things til you get to that point.
    cat back exhaust and CAI can be modded to fit a b-series easily
    upgrade brakes, suspension, better wheels and tires?
    or just save for the bseires it's a great upgrade, prolly the best thing you can do.
  4. ripperbone
    ripperbone angry bear
    Oklahoma
    or you can do a buget turbo setup. junkyard t25 or t28, hf manifold, eclipse intercooler, dsm Blow off valve
  5. preludebuddy
    preludebuddy Senior Member
    putting the rad in colorado
    for roughly a grand depending on the deals you get.
    I have two friends both with turbo'd d series motors. one dyno'd yesterday at 214 tuned and the other was 207 untuned.
  6. jasondw
    Thanks, I am looking into swapping my rear brakes out with disc instead of drum. Getting the Struts replaced soon and the alignment redone on it after that.
    I would be interested in hearing more about this :)
    I might look into swapping the head as well. Any more information you can give me on this as far as performance wise? Not how-to but what it would give me. Any information is much appreciated. Thanks!
  7. jasondw
    sweet deal. thanks for the info.
  8. VTECin5th
    VTECin5th Administrator
    Phoenix Az
    Blanco has the best bang for the buck idea...it would be first to do on my list.
  9. phunky.buddha
    Dallas / Fort Worth, TX
    Junkyard turbo- first learn how to read compressor maps, then shop around junkyards for cheapie but good condition turbochargers from OEM setups like the Ford Probe, WRX, Eclipse etc. You can build a manifold with an old HF or STD log style exhaust manifold from an 88-91 Civic, then start fabbing up piping for everything else on your own. Cheapo options for the intercooler and blow-off valve can come from pretty much any other OEM source too. Tuning is taken care of by cheap options like Uberdata or Crome if you know how to play with fuel maps, then adding some used injectors.
    If you read up a ton, know what you're doing, and are willing to weld a bit and cut up some stuff- you can be done with a reliable junkyard turbo setup for under $1000. I'm doing it on my truck, and I'm only $200 into it.
  10. jasondw
    Thanks for the info. I'm not THAT mechanically/fabbing savey (sp?). But, know how to weld, only problem is that I don't have a welder and don't know anyone who does :cry2:
  11. phunky.buddha
    Savvy. [​IMG]
    It really doesn't take much- you can buy adapter plates that bolt onto old exhaust manifolds. Go read up on homemadeturbo.com (I think). They can refer you to quite a few places to buy things so you don't even have to weld stuff together.
  12. jimboburgess
    nyc
    A budget turbo setup does take alot of custom fabrication. One of the most expensive parts the manifold would require planning and previous experience.
    but do read on www.homemadeturbo.com that is a great site and most peopel on there have some turbo experience.
    I build my turbo setup for less than $500.
    using 1g eclipse parts. manifold turbo bov
    www.johnnyracecar.com for a $155 intercooler
