AMERICANBULLY
Ok im not a tech so please bare with me. I have a jdm b16a swaped into a 91 integra, took wire harness, and injectors off the b18a1 motor. Used a obd-0 to obd-1 jumper harness. Running a gsr p72 ecu. All sensors are hooked up knock, o2's, and have no check engine lights. I do get my oil light coming on when i push it.(i think this has to do with oil being thinned by gas) did a compression check, and all cylinders are even at about 180. Did an oil change lastnight changed ecu to a p30 drove 30 miles checked oil and the is gas in oil again. Any and all suggestions would be seriously appreciated
