Will D trans vss work in LS trans?
scuzz
I'm getting vss error 17 on my OBDI hatch with LS engine/trans. Will the vss sensor from my D trans work in the LS trans?
Autozone shows a different part number, so I don't know whether to try it of find Integra sensor.
Yeah, I thought I'd try it anyway tomorrow. Just trying to save a couple hours labor for nothing.
Thanks
The mounting bracket may be different but you can use the top part of the sensor and works fine. I just did that on a customers swap resently and works good. Just make sure you use a manual transmission speed sensor.
