12volts white + brn conn abv fusebox
Starter black/white + brn conn abv fusebox
Ignition black/yellow + brn conn abv fusebox
Power Lock green/white - in drivers door
Notes: Door lock module in door above the speaker. the wires can also be foundat the anti-theft if equiped.
Power Unlock green/red - in drivers door
Notes: Door lock module in door above the speaker. the wires can also be found at the anti-theft if equiped.
Lock Motor
Unlock Motor
Disarm Defeat
Parking Lights+ red/black grn plug top of f-box
Parking Lights- white/black anti-theft module
Notes: the anti-theft module is located under the drivers seat. only some models are equiped with anti-theft.
Hazards
Turn Signal(L)
Turn Signal®
Door Trigger lt green/red - driver kick panel
Dome Supervision
Trunk/Hatch Pin grn/blk 2 silv dots - blu conn above fusebox
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer blue AC 2-pin plug near distr.
Notes: Also at round gray connector next to hood strut.
Horn Trigger blue/green - steering column
Notes: can also be found blue/red at anti-theft if equiped
Memory Seat 1
Memory Seat 2
Memory Seat 3
