Wiring colors different on my h22 harness
Nickg4c
Member
Ok so today I took out my Accord harness (1997 Lx) and started connecting it to the H22A4(1997). I ran into a few problems. I have searched all over and no one seems to have these problems.
1st the Vtec pressure switch, the wire was said to be light blue on the prelude harness. On mine I have two wires one is Light blue with a black stripe and the other is light brown with a black stripe. So my question is witch do I connect to Pin D6 and which is my power wire.
2nd The IAB the wires running out of my connector are Black with a yellow stripe and Red with a blue stripe. So is my red and blue wire the same as what should be a pink wire?
3rd. The connectors for the Injectors are different, so can I take the ones off the prelude harness and splice them into where the Accord ones are?
Thanks for any help.
1. Light blue to D6, the other one should be black and go to ground.
2. Yes, red/blue to ECU, black/yellow should go to a keyed power source.
3. I believe so, if you aren't changing OBD or impedance.
