wiring for 97 cx hatch
Discussion in 'HYBRID -> EG-EK / DC' started by tom, Dec 20, 2002.
  1. tom
    tom Junior Member
    anybody know which plugs for which sensors i have to rewire for this swap, it is for 96 ls motor in a 97 cx hatch? i think there was like 5 plugs that did not plug in
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    what harness did you use? did you keep the ride OBD2?? or convert it?
  3. tom
    tom Junior Member
    ok swap is done, wiring is done, using the 97 cx wire harness with a 96 ls ecu, still obd2, only problem now is the iac vavle and the sensor at the oil pump, the cx harness has 3 wire plug and the ls iac has 2 wire plug, and the sensor at the oil pump is a 2 wire plug and the cx harness is a 3 wire plug, C.E.L. pulling up on #14 iac vavle, how do i wire these sensor up
