Wiring For D16z6 Head On D16a6 Block
Discussion in 'ECU's, Electronics, and Tuning' started by c8r9x_si, Feb 1, 2003.
  1. c8r9x_si
    c8r9x_si Junior Member
    im thinkin about doing a mini me swap but im not sure about the wiring...if i were to go with a p28 ecu how would i go about connecting it??? im going to use the distributer that came with the head but what intake manifold should i use... my crx's or the z6's? if i were to use either one, how would i got about connecting it to the ecu any help would be great. thanks
  2. hybrid4
    hybrid4 Senior Member
    Nashville,TN
    if you keep your ecu , the a6 distributer will do fine. just bolt the head up to your stock intake, run the vtec and your good to go. just get a vtec controller so you can adjust your fuel maps. if you go with the p28, get a harness from hasport, and run the z6 dist. if you use the z6 i.m., the wiring is a little harder. if i were you, i would choose option 1. hope this helps.
