wiring for mini me swap
dj30224
i have a 1989 honda civic std canadian model im gonna do a mini me swap i have everything to do the swap exept wiring i need to know what wiring i should use someone told me that 92-95 ex wiring would work but said i would have to run two additional wires to the engine any help would be useful
thanks,jason
you need to use the engine harness that is on your car and make the wiring changes to it to convert from DPFI to MPFI, and also add any other wires required for VTEC, etc. - engine wiring harnesses are not interchangeable
-P28 ecu ('92-'95 Civic EX/Si)
-B/S/T forums here and on Honda-Tech.com
-Boomslang Fabrication's obd0 to obd1 harness
-Click me
-obd0 to obd1 Distributor adapter
-B/S/T forums or make your own. (my sig)
