wiring HELP
Newguy
me and a friend are doing a swap in his 90 dx to a b16 and im not sure how to do the wiring any help would be great thanks
just do a search of VTEC wiring, you'll find this has been covered a zillion times. Also if its DPFI, you can find into on the conversion to MPFI when you search.
http://jkobd.com/
this guy is a member here, username = jkobd
this will make it much easier if you are inexperienced, but also more $$$...
search here or google...
tons of write ups for both DPFI->MPFI and B16 wiring...
once you get to MPFI it should be pretty easy...
