wiring jdm gsr into 92 civic cx
Discussion in 'HYBRID -> EG-EK / DC' started by acurateg96, Sep 26, 2005.
  1. acurateg96
    acurateg96 Junior Member
    does anyone have any links or info on how to wire it up. ive seen them for dx and vx, but not for cx's. is it basically the same?
  2. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    www.c-speedracing.com does a good write up. I'm not positive about the differences between the CX and DX/VX, except the O2 sensor is on one wire instead of a 4. (On my CX atleast.)
  3. Eg6nRpS13
    Eg6nRpS13 Junior Member
    if you have a 92 civic cx that year for eg's is plug and play, the only thing you have to do is run the knock and the iab's. Its even prewired for the 4 wire o2. If you got money buy a usdm gsr engine harness and plug everything up run the knock sensor and the iab's. If you dont you have to reuse your cx harness and run a a few wires, if your going this route you can find almost all the into you need in the search.
