Originally posted by acurateg96@Sep 26 2005, 09:34 PM does anyone have any links or info on how to wire it up. ive seen them for dx and vx, but not for cx's. is it basically the same?
www.c-speedracing.com does a good write up. I'm not positive about the differences between the CX and DX/VX, except the O2 sensor is on one wire instead of a 4. (On my CX atleast.)
if you have a 92 civic cx that year for eg's is plug and play, the only thing you have to do is run the knock and the iab's. Its even prewired for the 4 wire o2. If you got money buy a usdm gsr engine harness and plug everything up run the knock sensor and the iab's. If you dont you have to reuse your cx harness and run a a few wires, if your going this route you can find almost all the into you need in the search.
