Wiring problem
4drteg54321
Ok, i bought a 1998 honda civic ex coupe and it had the D16Y8-Vtec and am swaping a OBD1 gsr into it. Is and there any wiring i need to do? Beside the IAB because i see all the vtec wiring and knock sensor. Is there anything am missing?
Depends do you have a 3 wire IACV or 2? other then that just use Obd-2a to Obd-1 ecu jumper harness and Obd-1 ecu and your set :thumbsup:
The one on d16 is 3 but i have the one i also have the gsr engine harness so am just switch the plug. Is that all am missing?
