wiring question
Discussion in 'General Tech and Maintenance' started by spiritofjosh, Feb 10, 2009.
  1. spiritofjosh
    spiritofjosh know your role!
    ocean gate nj
    Im about to put in my d15b into my eg hatch and im finishing up all the wiring but I noticed that on the intake manifold for my old non series vtec i have the evap solonoid valve and on the d15b i dont, there doesnt even seem to be anywhere to install one. the si wiring harness im using has the extra plug for this valve but since its not there i dont have anywhere to plug it into, is this going to throw a CEL when i get it all in the car? my next question is the map sensor on the d15b can be plugged in but it snapped off the tb, but the one off my old stock motor is intact...theres different serial numbers on each but can i take the one from the old motor and put it on the new one? sorry if these a noob questions but engine wiring is definatly not one of my strong points.
  2. serrilion
    serrilion In my own little world! VIP
    Vermont
    I would say the map sensors would be interchangable if it were a VTEC motor it came off from but from a non vtec motor idk, sounds kind of iffy there! just my 2 cents
  3. 97hatch
    97hatch ?
    Anderson IN
    should be able to interchange map sensor
  4. spiritofjosh
    ocean gate nj
    the map sensor is changed, im wondering about the solonoid thats behind the intake mani, its on my non vte but not the vtec, there isnt even a bracket to mount it on. im not home but i will try and post pictures, without it i now have a loose plug and a tiny loose hose.
  5. govic
    govic New Member
    where did you put the hose from the charcoal canister to that solenoid vave?
    I got rid of the solenoid and left the plug loose, the car runs fine.
  6. spiritofjosh
    ocean gate nj
    thats exactly what i have going now, the hose is just flopping around, i mean its not bothering me but i didnt start the car yet with the new motor and i dont want a cel
