wiring vtec help
Discussion in 'ECU's, Electronics, and Tuning' started by iwant2drivefast, May 19, 2005.
  1. iwant2drivefast
    iwant2drivefast Junior Member
    Nothwestern Oregon
    i thought i hooked up the wires right but im still getting the 22 code. here is what ive done. green/yellow wire hooked up to ecu at a04, blue/black wire hooked up to ecu at d06, black wire hooked up to ecu at d03. the blue/black and black wire is in the same plug. this is all happening in a 93 civic lx with a d15b.
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Did you clear the code after the fix?
  3. pissedoffsol
    what ecu are you using?
  4. iwant2drivefast
    Nothwestern Oregon
    not sure how to clear code. using the p08 ecu
  5. iwant2drivefast
    Nothwestern Oregon
    i unhooked the battery for about 20 min. started the car and still getting the same code 22. is the vtec pressure switch and the knock sensor really contained in the same housing and small wiring plug?
  6. xj0hnx
    C.C.TX.
    Pressure switch is D6, Knock sensor is D3
  7. iwant2drivefast
    Nothwestern Oregon
    i unscrewed the oil pressure switch from the housing. is the knock senor part of the oil pressure switch? as far as i've been able to understand from these posts are, the 2 wires coming out of the switch are; 1 for oil pressure switch, the other for knock sensor. i'm i way off here or what?????
  8. xj0hnx
    C.C.TX.
    Yes, you're way off. The knock is it's own sensor.
  9. iwant2drivefast
    Nothwestern Oregon
    so what are these two wires for and where do the go??
