Wiring Vtec
Discussion in 'ECU's, Electronics, and Tuning' started by Havok, Jan 20, 2003.
  1. Havok
    Havok Senior Member
    Florida
    Alright, I need someone who knows how to wire VTEC, I am electronically challenged, I am proud when I hooked up my Xbox right :) Anyways, here is the VTEC solenoid...where does it hook up to, where do I run the three wires, etc?
  2. Havok
    Havok Senior Member
    Florida
    Ok, I pretty much got it, I have to add to wires to my current harness, or buy a Z6...How easy is it to add the wires and run them theu the firewall to the ECU?
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    I got lucky and didn't have to,but my friend did and he said it was really easy.He just got the right ends to plug it into the ecu then ran it along his harnes taping it in,then went though the firewall where his power wires for his stereo went though.
  4. Hybrid93Hatch
    Hybrid93Hatch Member
    Will a 98 GSR vtec solenoid look the exact same? I'm about to drop the GSR in my 93 Cx and have to wire vtec as well.
  5. D See 2
    D See 2 Senior Member
    Baltimore, MD
    no, it will look different, but the wiring will be the same.
  6. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    back from the dead yO!.
    january!!
  7. RFHOMI2U
    RFHOMI2U Senior Member
    Do you have to Convert wires around on the harness for going from non-vtec crx si to an obd1 z6 motor? or just run the vtec wires to b5 and a4?
  8. Havok
    Havok Senior Member
    Florida
    you :cockblocked: my thread, asshole
  9. bossman032
    bossman032 Senior Member
    lol :worthy:
  10. sabi670
    sabi670 Member
    Afipunk 21, are you running a 96+ ecu, if so could you tell me what pins to plug the vtec wires into on the ecu? Im doing a y8 mini-me on a y7.
    also could you tell me how your swap worked out? (performance wise)
    Thanks.
