93 honda civic vx hatch.
built lsvtec
95 b18b1 block
oem honda pr3 b16 pistons 11:5.1 comp.
oem honda piston rings
arp rod bolts
oem honda crank and rod bearings
type r oil pump
gsr water pump
gsr timing belt
oem honda headgasket.
hondata intake mani gasket
p30 b16 intake manifold
dc sports race header with 2.5 inch collector
2.5 inch exhaust with 2.5" vibrant muffler
golden eagle lsvtec kit
99 b16 head
supertech valve springs and retainers
gsr cams
gsr trans with act clutch
chipped p28 ecu
with cams and a tune car will easily go low 13's. as of right now best time is 13.9 on bf drag radials.
its captiva blue with a new front end. so the front is black. has a dent and small rust on driver side quarter panel. other than that its clean. rides smooth. stock suspension in the back with coilovers up front. real jdm headlights with jdm corners. ek yellow fog lights. cf duckbill.
gsr rear cloth seats and integra ls cloth front seats. clean black interior. 226k on the shell. clean title. comes with steelies and hub caps with brand new tires.
built lsvtec
95 b18b1 block
arp rod bolts
type r oil pump
gsr water pump
gsr timing belt
99 b16 head
gsr cams
chipped p28 ecu
