Wrecked DA new EF, what can I use?
Discussion in 'HYBRID -> ED-EF / DA' started by ramone167, Apr 3, 2008.
  1. ramone167
    ramone167 New Member
    Jacksonville FLORIDA
    I recently wrecked my DA.( r.i.p.). I have a 90 Si hatch, I plan to swap motor (OBD1 B16a) and other components, if I can. My questions are:
    1. Can I use any of the suspension components from my DA on my EF? (knuckles, control arms, axles, shocks...etc)
    2.Let me know if I'm missing Anything. Obd conversion requires
    a.ECU jumper harness
    b.Dist. rewiring/harness
    c.Injector clips switch? may or may not need to be done?
    d. 02 sensor
    3. Does this mean I can just plug in harness without changing clips/plugs for every sensor?
    I have performed engine swaps. I had never converted OBD. I know this information has probably been posted a thousand times. If you dont want to answer any questions PLEASE post links to info.....Thanks everyone
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    you can use the complete suspension setup..for the rear disk brakes you will need yo take everything,trailing arms,hubs,and the ebrake cable
  3. ramone167
    Awesome, I thought that was the case but, I wasnt sure....
  4. ramone167
    Anyone else? How about brake booster/master cylinder? or OBD info?
  5. INJEN78
    INJEN78 HS LEGEND
    OHIO
    yes you can take all that too...and the proportioning valve as well,,,as for the obd shitjust go to rywire.com,,,they have everything you need to go from obd0-obd1
  6. ls/vtechatch91
    ls/vtechatch91 New Member
    washington
    its an si it should have rear disc already....
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    nah not all of em came with discs,,
    ive got drums on mine as well
  8. Hasid Lafre
    Hasid Lafre Master of the obvious
    From what I have read the only Ef model anything to get rear disks stock is the 91 jdm sir rex.
  9. BrokenRex
    BrokenRex New Member
    USDM 90 and 91 Si's came with rear discs, 88 and 89 got the shaft... the one that's connected to their brake drums :p
  10. verderacer
    verderacer New Member
    Yup, my 89 Si has drums :-(
  11. 91_civic_si
    91_civic_si New Member
    Wasilla, Alaska
    Yeah but only on the crx. The civic didnt have rear disc until they made the eg model.
  12. INJEN78
    INJEN78 HS LEGEND
    OHIO
    correct,,i wish i had rear disks:(
  13. BrokenRex
    I was fairly certain that the hatch didn't get them, but I wasn't sure, and would rather make an ass of myself than type out "i think." I've only owned rex's, forgive me.
  14. Hasid Lafre
    Hatches dont ahve them cause round here theres who we call the twins theonly difference is the year. ones 90 and ones a 91, both si's, Both drum brakes.
  15. ramone167
    My 90 Si hatch definitely has rear drums.....so thats the complete rear setup: knuckle, uca's, lca's, trailing arm and all cables? and as for the front, just the knuckles? I would like to stay within specs as much as possible.
  16. INJEN78
    INJEN78 HS LEGEND
    OHIO
    yep the entire setup,,for the front i think you can use the control arms too!!
