M marek Junior Member Mar 22, 2005 #1 In the 92'-93' integra b16a swap, it says XSI in parentheses, i was just curious wat this actually means.
B b16efhatch Senior Member Mar 22, 2005 #5 My b16a swap was out of an xsi, I think, the tranny is an S1, ecu is PR3. I read somewhere that the xsi ecu has better fuel maps
B brian11to1 Senior Member Mar 22, 2005 #6 XSi is a trim level. It basically means GSR. More than likely an XSi swap should come with LSD and a YS1.
B B16CRX Senior Member Mar 23, 2005 #7 I was under the impression that 92-93 was big spline YS1....could be wrong. prolly not LSD though...
B b204dr Senior Member Mar 23, 2005 #9 no xsi is a b16 integra not b17 - b17 came in 92-93 integra gsr's
xj0hnx I wanna be sedated VIP Mar 23, 2005 #11 B17A1 is a USDM only motor, in Japan, where the RSi/XSi was released, they had B16As.
B brian11to1 Senior Member Mar 23, 2005 #12 Again, XSi is similar to GSR. It came with LSD in Japan. No, the YS1 GSR's did not come with LSD here in the states.
B B16CRX Senior Member Mar 24, 2005 #14 http://www.allmotorhonda.com/techpages/B-s...ranny_specs.htm this tells you what tranny code goes to what car (and their gear ratios)
