z1 head on z6 block help
Discussion in 'Engine Building' started by competitiveaudioman, Jul 22, 2008.
  1. competitiveaudioman
    competitiveaudioman New Member
    well after finding out i have a bad z6 head I'm now going to use my spare vtec e z1 head. i was just wondering what my compression ratio will be with this set up? I'm running a bone stock rebuild and a metal oem 3 layer z6 head gasket. I'm assuming my stock p28 ecu will work with this compression right?? any info is appreciated.
  2. jOnZ
    jOnZ JDM jOn
    Lowers your compression people have done this setup for boost.
  3. competitiveaudioman
    it will raise it. the z1 has smaller combustion chambers. a calculator i found online put me at 11.1 cr.
  4. jOnZ
    jOnZ JDM jOn
    Ahh, my bad its the other way around z1 block z6 head that lowers sorry. I read wrong :p
  5. competitiveaudioman
    its all good. thanks anyway tho
