z6 in ef Help
Discussion in 'Civic and CRX - EF' started by slayer1927, May 18, 2011.
  1. slayer1927
    slayer1927 New Member
    Ok so we went to the junkyard and found a perfect z6 with harness and ecu . We are going to do the swap next week . I need to know can I use the stock obd0 or do I need to use a jumper and what problems will I run into?
  2. RHDism
    RHDism Right Hand Drive guru
    Unless your EF is an Si, you will need to convert to mpfi. Definitely go with obd1, and a p28 ecu.
    Otherwise its a fairly simple swap. Post pix.
    Any problems or issues you might run into are covered with good write ups here or H-T.
  3. D16SiHatch
    D16SiHatch New Member
    keep the stock harness and convert it to mpfi if your car isn't an Si or Hf. as said above, get yourself a p28, and convert to obd1.
  4. Jeef
    Jeef NO MA'AM Moderator VIP
    If a dx you need to upgrade to mpfi. Make sure you have the parts to do that before you start your swap. Technically you can run an obd0 mpfi ecu and use a tach or toggle switch to activate vtec. Ghetto but it works. I had to do it when I did my swap like 10 years ago. A month or two later I got an obd0 to obd1 harness adapter and a p28. A much better way to go.
  5. slayer1927
    Ok sounds good we have already went mpfi it has problems but we are things it is with the air intake , So what I am going to do is swap motors the ecu will work and I will take the harness out and fix it up to work better since right now the wires look bad.
  6. Jeef
    Solder all your connections.
  7. crxtego
    crxtego New Member
    can any tell me how to wire my hARENESS FROM DPFI TO MPFI IN MY 91 CRX DX IM PUTTIN IN D16Y8 WITH A P75 ECU FUCK IT CALL ME 407 300 8609
  8. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    plenty of threads their cheif, god i hate greenhorns
