zc swap
Discussion in 'HYBRID -> ED-EF / DA' started by Yspeed, Jul 15, 2005.
  1. Yspeed
    Yspeed Member
    Ontario, Canada
    I just put an 90 zc in my 89 hatchback and it just won't start it turns over and there fuel, but no spark I was trying to use the 89 distrubutor then I tried a 90 and that still didn't work. I'm pretty sure i have the wiring right, but I'm not sure. I just lined up all the colours and connected them. I also wired the tdp sensor wiring right. thanx for the help
  2. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    I think (but don't remember correctly) that you had to switch some wires around on the distributer. Check some of the wiring diagrams for the zc swap. The motor will run with a minimal amount of sensors, but the distributer is definetly a part that has to work.
    This should give you a start, but look around for better sites.
  3. Yspeed
    Yspeed Member
    Ontario, Canada
    thanx alot I will have a look and do some more reseach.
