pappaj
I just bought a crx and it failed emmisions so I advanced the timing. I followed the zc manual I found zcr.com for timing the motor. I must be doing something wrong because it calls for timing 16deg. btdc there isn't even enough movement in the distributer to acheive this. I am also not positive I unplugged the right plug for the electronic advance, does someone have a picture showing where this is located. Also does this spec 16deg btdc mean while running with a timing light or is this static timing. I am going to try one more etest with the timing retarded and regular gas and hope the thing passes. Some guidance would be appreciated.
