90 accord tranny problems
  • Thread starter Thread starter sxyhnda
  • Replies Replies 15
  • Views Views 2K
sxyhnda
i have a 90 accord with F22 5-speed. the tranny is shot and was considering upgrade to a tranny from h23 or h22. i was wondering what would be best/easiest, and would it even be worth the trouble to go w/ tranny from prelude
is the gearing shorter on a h22a trans? does anybody know how i can get the specs on them? i have a stock motor and need all the help i can get.... lol also how easy is the install on one?
Yes, the gearing is shorter. For the specs, just do some searching. I know somebody posted something about this not too long ago. Also, there may be an article in the reference section about gear ratios. Well, I know for a fact there is but I don't know if the F/H-series is covered.
Installation is exactly like stock. F and H-series engines and transmissions are completely interchangeable (aside from the S2000 drive-train). If you have a repair manual for your Accord then just follow the directions there.
i think what he meant is are the mounts the same? my accord has 2 mounts from the chassis to the tranny. are these going to work the same on an h22 tranny? or will i have to rig something?
Unless you're swapping from auto-to-manual you shouldn't need to change anything...
i'm seriously considering swapping a jdm h22 tranny with the lsd.... where would be the best place to find one? are they hard to come by and are they expensive? i know my car top to bottom but i'm new at this modifying and swapping thing, so i don't know exactly where to find parts......
id like to elaborate on my situation a bit.... as said b4 i have a 90 accord, f22a1 5 speed. the tranny works fine under normal driving, just as good as new. yet when driving it hard it refuses to go into second until the rpms come down. speed shifting is out of the question.... third grinds when shifting hard at high rpms, and has done so for some time, but it will go in with some force. 4th is always fine, and 5th grinds on occasion. it also refuses to go into first sometimes, such as when stopped at a stop light. i don't know much about trannies..... is this a synchro problem? is there anyway it could be the linkages? i had some problems with them a while back when i rebuilt the motor... any input helps......
Dude i'm trying to sell a jdm h22 trans. It's not lsd but I'm selling it pretty cheap. It grins a little in 3rd but not bad at all. If you are interested let me know. About 60k on it. Letting it go for 500. They're 6-800 on ebay. Will send pictures if you are interested, and answer any ?s you may have.............
i got a lot of other cosmetic work to do on my car b4 i start this tranny project. i'm sort of just researching and looking into my options at the moment. beside i don't think i have the money at the moment to even buy a tranny..... thanx anyway man.
Hey thats mine!!! :D:D:D Just kiddin tho i dont think ima need it dude im gunna buy the whole swap with the lsd from hmotorsonline
