Offensive remarks removed, D.
but as far as lug nuts go, they are slightly different, but it only applies to alloy wheels. they have a ball type seat, but thats the only difference. steel and alloy wheels have a different lug nut for each. that is due to the taper of the seating area on the wheel itself.you can not interchange the 2- you will end up with either a stripped stud, a jambed nut due to over-tightening the nut trying to get the nuts tight ( i see that a lot when guys try to put steelies on the front using alloy lugs) or a broken stud. running around with lugs that are not seated will do 2 things- damage the wheel or break the stud off. the wheel gets damaged as the wheel wobbles around, destroying the lug seat on the wheel, and i shouldnt have to tell you what happens when studs start breaking.
an undamaged lug nut should spin onto the stud with your fingers. if there is any tightness or binding, stop- the lug nut or the stud is probably damaged and should be replaced. try another lug nut, if it spins on easily, replace the damaged lug, if it does the same, get the stud replaced.
DO NOT UNDER ANY CIRCUMSTANCES USE ANTI SEIZE COMPOUND ON LUG NUTS OR STUDS!!!!!! during normal driving heat will slightly expand the nuts, and anti- seize or any kind of lubricant on the threads will allow the nut to unscrew. studs and nuts should be clean and dry, any rust or crud should be removed with a wire brush.
use a touque wrench to tighten lugs- check owners manual for the proper spec, tighten lugs in a criss cross pattern. over tightening the lugs WILL warp brake rotors. most hondas are 85 ft. lbs, some models are different, check to be sure.
