MisterMister
USDM whore
Whats going on guys.
Let me give you a little background on my self. I had been pretty into the Honda scene for a good 10 years. Starting out with a Del Sol with BPU upgrades (sold), and ending up with a pretty tricked out 00' Civic Si coupe (stolen).
I have since moved on to RWD cars, getting an S13 240 and a '91 SW21 Toyota MR2. I am now looking at getting back into the Honda scene after doing some soul searching and research. I really did love my Si to death and have come to further love that car (even after it's loss), making the decision even easier.
Now, all that being said, I am wrestling with the idea of putting together a hatch, as so many before have done. I always wanted a hatch, even when I was building my Si coupe due to its modability and its light weight. Not to mention the fact that I think these are some of the better looking Hondas to come out in the 90s.
After some thought, I have almost made up my mind to build an EG hatch. The recent article in SS about the K20 powered JDM sweet EG hatch have even further blown my thoughts in that direction.
Now, I was thinking of going with the tried and true LS-VTEC turbo build, but now I am not so sure. The K series swaps are looking better and better, and their power production is such that I might not even bother going FI. However, this is where it gets tricky.
I am a B series guy. Always have been. Thus, I know jack squat about the newer K series swaps other then the fact that they make some decent power in NA builds and that there are a myriad of swap options available for all sorts of Honda chassis.
This is where you come in. I am thinking of a K24 swap due to the better drivability and increased torque, but that raises further questions such as available aftermarket parts, maximum potential, and swapability. Right now, I am looking for a straight swap without ant custom fabrication. If that means going with a pre-made engine mount kit, so be it, but I would rather not have to do any firewall work or the like, nor do I want to loose things such as AC and power steering.
Whats more, I am looking to keep at or near the stock curb weight. No gutting the chassis. No massive diet plans. I like my hearing and am not too keen on removing all of the sound deadening material. That being said, I dont want a simple 14 second car. If this is going to be an NA build, I want this thing to be at least deep into the 13s, all while keeping its composure and drivability on the street and at the auto-x.
Anyway, the bottom line is this:
I am looking for;
Daily drivability
Modability
At least mid 13 second ETs
Balance for competitive auto-x and road race events
With all that in mind, I welcome your comments and advice. Any and all will be welcome. Furthermore, I thank you in advance for anything you may offer.
-Joe
Edit: If anyone cares, here is my old ride:
B18C5 long block
B16A2 head
SS valves
Ti retainers & springs
RC 370cc injectors
JDM ITR header
Password JDM J's Racing style carbon fiber intake
Omni Power 2.5" test pipe
RS*R EX-Mag cat-back exhaust
Exedy full face clutch
ACT 12lb street-lite flywheel
Energy Suspension motor mount inserts
Energy Suspension shifter bushings
B&M S bend stainless steel short shifter
JDM CTR shifter boot
JDM Accord-R 5spd billet shifter knob
AEM 12" slotted front rotors, 11" rear rotors
BF Goodridge stainless steel braided brake lines
Hawk HPS brake pads
Motoul RBF600 brake fluid
KYB AGX shocks/struts
Skunkworks GS-R coilovers (original, not Skunk 2)
SRR rear lower tie bar
Walboro 190lph fuel pump
Rota Circuit 8 16" rims (gunmetal)
Hankook Ventus RS2 tires (215-45-16)
Uberdata chipped P28 ECU (chrome)
Skunk 2 Stage 2 cams
Skunk 2 cam gears
Spoon Sports 2 layer HG
milled head (.30mm)
Skunk 2 intake manifold
Hondata intake manifold polyurethane gasket
BBK 65mm port matched TB
Dyno tuned by Bubba @ Do-It-Dyno
I am looking for;
Daily drivability
Modability
-Joe
B18C5 long block
B16A2 head
SS valves
RC 370cc injectors
JDM ITR header
Hawk HPS brake pads
Skunk 2 cam gears
milled head (.30mm)
