Brake Lights?
1sikef
Alright When Push The Brake Pedal Down My Brake Lights Dont Come On, But When I Turn My Running Lights On The Brake Light Stay Lit With Them, I Checked Fuses Grounds No Luck? So If Anyone Has And Ideas In What The Prob Is OR Suggest What Exact Grounds To Check It Will Be Appreciated?
Are you saying that when the running lights are on, the brake lights come on and stay on with them? Either way, I guess you could check the brake light switch on the brake pedal for starters...
How Long Did It Take You To Type Every Word With A Beginning Capital Letter? Lol.
If you got a repair manual with the wiring diagram it's pretty easy, just find out the colors and trace them back and check for any wires that are touching.....the brake lights i think are on the same circuit as the horn so you can check to see if that also works.....sounds like they some how got wired into the turn signal circuit....kinda weird????
the brakelights are on the same line as the horn and the "open door" light and noise line.
All of my brake lights recently went.. my horn didnt work and when i stepped on the brake pedal the open door "beep" noise would come on. Annoyed the piss out of my friends
