itrsleeper
Gotta bunch of random stuff up for sale check it out, every thing is obo!! but buyers pay shipping (everything will be shipped flat rate for $10 as long as i can fit it in flat rate box)
B series LS parts (every thing was pulled of running motors, none had any leaks. One had bad rings and other had blown head gasket)
-Water pipe (from water pump to thermo housing) got 2 $10 each
- Water pumps (both work no leaks) x2 $10 each
- Thermo housings x2 $10, $20 (for one with water neck and thermo)
- Oil Pump $10 (works no leaks, seal still good)
- Upper Alternator brackets x2 $10 each
- Lower Alternator brackets x2 $10 each
- Evap can $10
- Timing belt cover (lower) x2 $10each
- Rear main seal $10 (no leaks seal still good)
- Crank timing belt pulley x 2 $5 each
- Drivers side motor mount $10
- Oil pan $10 (has dent on front corner, and has scrapes, doesn't leak)
- Oil baffle $10
- Oil pick up $10
Misc. Distributor parts
-Housings $10 each (GSR, LS, B16, i think...cant remember obd1 and obd2)
- ICM (igniters) x 6 $10 each (these things sell for almost 200 new!! but dont know if they work, cheap way to try and fix dizzy problems)
- Internal Coils $20 each x 4
- Internal pick ups $10 each (things with gears on them, actually are crank pos. cam pos. piston pos. sensor pick ups)
- caps $5 each
- rotors $5 each
Misc injectors $5 each
B-series vtec solenoid $50 ( broken wire, just needs terminal end crimped back on, easy fix!)
D15 vtec cams $40 each obo
PM6 88-91 civic/crx si ecu sold
PM9 88-91 civic std ecu $40
USDM ITR valve cover sold
CTR gauge cluster bezel $20 shipped
B-series power steering pump with aem pulley and mounts $60 obo
ITR fuel rail $50 obo
B-series alternators all working 2-obd2 and 1-obd1 $40 each obo
B-series intermediate shaft $60 obo
B-series starter sold
more stuff to come.....................thanks for looking!!
- Evap can $10
- Oil baffle $10
- Oil pick up $10
- caps $5 each
- rotors $5 each
