civic
  • Thread starter Thread starter azncivic
  • Replies Replies 7
  • Views Views 1K
azncivic
I have Honda civic the motor blow i found a b18a with tranni and the guy told me it will fit and plug up to all wire harness will it drop in n go i this ture ??????
MPFI? If so....your harness will work but you need OBD0 teg axles and you need a motor mount kit for your car and an aftermarket shift linkage or cut/weld the teg one.
the OBD0 ECU that came with the B18A too
Don't think its much more then that
companies make them
Hasport makes good ones for your ahtch with the LS just make sure its specific for your car
i effin lol'd all 12 times i read this. is the new motor good shape?
