92stoccord
Big Member
Thanks byron, I'll check that out next time I'm home. It just got a hell of a lot harder to work on it. I just moved up to Kent. I'm practically your neighbor now.
Is that ground run to the frame rail then?
Yep it is, when you think about it your motor is isolated by rubber, you have a positive going to the starter, without a good ground you dont have a complete circuit.it should be
<-has been running without the VC ground for 2 years.
i pull the vc ground off on all my cars..<-has been running without the VC ground for 2 years.
is this the truth?^^Would burn cleaner, get better gas mileage, and have more power if he'd attach one.
