B18B Stopped Running! Help!
ballerxforxsho
alright, so its a 95 teg, LS head. he was driving it and it just quit randomly and wouldnt start again. prior to this, car had no problems at all and has had thse mods on it for awhile. when it stpped running we changed the plugs and wires. havent done anything else. heres a list of mods it has incase anything might throw it off from running. ANY SUGGESTIONS ARE GREAT!
-4-2-1 header, into test pipe, to stainless steel Greddy exaugst, no cat no nothing.
-AEM cold air intake
- idk what else haha
yes theirs power, yes im almost def dure theirs spark, and we just replaced the whole fuel filter system cus we thought that was it.
yeah sorry, were not all integra experts here. and what about the timing belt? is it one peice? yes
@ZCopweredSI - if your gonna hate hop off the thread. you ask me if it has fuel, spark and if it turn over like im a dumbass. like i didnt check that or anything. bottom line, stop hating or get off.
check to see if the injectors pulse when you crank it. if you have spark and fuel pressure, you might not be getting a signal from either your crank or cam sensor.... check the ground cable that goes from the valve cover to the radiator support, and also check the ground cable that goes from the passenger side frame rail to the trans case bracket.
hes not hatin dude hes helpin but if u wanna act like that u are a dumb ass.
Now when u try to turn it over does it sound like the cam gear is free spinning real fast? have u pulled the plug out to see if its getting spark? have u taken a fuel line off and turn the car on to see if the fuel pump is working? ur not giving a whole lot of info for us to help u ur coming in here demanding help pretty much and we are trying but ur acting like a DUMB ASS say zc is hatin on u greenhorn.
yeah it has fuel, and replaced the fuel filter and has pleanty of fuel pressure. and it has like weak spark but we just replaced the sprak plugs and the wires are new. is it possible the ignition coil is bad?
Yes timing belt is one piece. Have you checked the timing belt yet? Take the top plastic timing belt cover off (a few small bolts) and see if its in one piece still. What about the plugs wires? Are they for your LS or for some other motor? (like a DOHC VTEC)
And BoostedHatch is kinda right about the spinning....but if the timing belt snapped...it would be the crank spining and no cam gears moving. It would spin pretty fast too (faster then it did when it was running)
ive checked the timing belt, its fine, distriutor is brand new. goin to replace the fuel relay and see if thats it
Plug wires are the right ones? I doubt this is it though...it would still turn over....I think but you saying there is a little spark makes me wonder.
Main relay?
Well thats all I got good luck bro
