No chip ECU. I was suppose to get one but they guy didn't answer when I called him after work (Last Friday). And since the tune aint happening until I can get a weekday off, I'm in no hurry. I know 'some guy' that I can ask about the primary lobe sizes and if they are the same. I think I will check the plugs soon. They are pretty new.
I've got Auto Zone axles on my car. Been road racing on them for like 4 years now; no issues.
Yeah...I got the JDM swap ones it came with and I was thinking of re-building them (its easy just greasy time master fresh) but $125 is nice to just swap them out.
How long did you run aggressive cams on the b16 lma's? There's a reason Honda gave the ITR much beefier lma's. Most n/a built honda's I've came across made lots of valve noise - likely due to worn lma's.
Did you use stock ecu or custom maps with the ctr cams on your b16 ?Just because it got bumped, and this is related to this, I ran CTR cams on a completely stock B16A head for close to 7 years, revving the piss out of it, and not once in a while either![]()
