RickParker
I changed the head on an OBD2 b18 and got everything back together. It started and ran for a few minutes at idle but when i gave it some gas it shut off.. i have fuel and spark.. the timing is dead accurate with everything TDC on #1.. but the belt is a little loose.. how do you adjust that? would that being loose have any effect on it not starting again? im goin to change the dizzy cuz it was starting to go bad.. any other suggestions?
