im doing a swap and ran across a problem with the distributor wire.. im using a 97 civic ex wire harness and the distributor harness does not fit.. any idea if i should get it rewired or get a new distributor??
Make sure you routed the main harness correctly. You may need to extend some of the wire harness branches. This is easy with a decent soldering iron, heat shrink tube, and quality electrical tape.
If u are using the jdm diizzy that came wit the motor it wont work. The plugs between usm and jdm are different. Get a usdm b16 or gsr dizzy, swap em out, and ur good to go.
