hondafreak513
Well-Known Member
Yeah they have I would like to see what the new Sonata turbo will do..
I know youre going to bitch, but, enter the Camaro SS.There isn't a single other car on the market that competes with it at it's price point.
Factor in the flash, and you're at 28k, sticker.
You simply can't buy a car with brembos (biggest sold on any car under 100k at 340mm fronts 4 piston, 300 rears 2 piston) , 19's ,rwd, limited slip, leather where you want it, cloth where you don't seats, bluetooth, homelink, usb/ipod, compass, multiple power outlets, upgraded infiniti sound system with amp/subwoofer (its awesome, really), proximity keyless system for doors and ignition (just keep it in your pocket), sport suspension (it's pretty stiff), some tests have it pulling .94g on skidpads, capable of 30mpg highway, 10 yr 100k warranty, 275hp/340 ft/lbs (take wheel power after flash, up to bhp for sticker purposes and its about those numbers give or take)
The only thing that comes close is the S4. and it's double the price at over 50 grand, and awd, and has crappier brakes. lol
Chevrolet Camaro SS (2010) with pictures and wallpapersThe SS front brake package includes Brembo 355 mm x 32 mm vented rotors with four-piston aluminum calipers. Semi-metallic brake linings are used at all four corners on FE3 models for superior fade resistance and pedal feel. The rear brakes are vented Brembos measuring 365 mm x 28 mm, with aluminum four-piston calipers.
They're built on the exact same platform.GM is an all around terrible car company...the exception is the G8
They're built on the exact same platform.![]()
And who the hell makes a car with larger rear brakes? honestly?
