josh_crewdson@y
Will b18a internals fit a b18c1 block? (crank and main bearings)
No, you can replace rod bolts with ARP fasteners to keep things together. Proven to work up through 8000rpm with no issues.
I have arp rod bolts. We only rev to 7800 on stock ls rods.
With the gsr crank and rods we go untill the motor stops making power or up to 9500
Which ever comes first.
With valve train
Just plug em up you will have a bit better oil pressure
You only want to plug them if you're running forged pistons right?
