BAM son!!
vendor here .. lol
https://hondaswap.com/vendor-classifieds/private-label-mfg-power-driven-headers-h-b-k-series-255706/
Yep - it's tuning and tuning is tuning. Low "Q" or broad band power or High "Q" with it's inherent narrower power band and where in the power band to tune to.I read a pretty great article about pipe sizing. It seems as if a larger pipe decreases velocity and reduces scavenging but it rocks the power curve around its peak, rather than shift it dramatically in one direction or the other...
damn. nice read.
And eg:
Bam! yeah it's the same company.need to head out to see the crx t make sure I order the important stuff it really needs.
cams, I decided with the pro1's with springs and retainers.
holding off on IM and throttle body until I see the OBX ITB's on the other epicness thread.
going to also get some control arms, bushings and ES stuff for suspension.
other than the k sport coilovers every rubber under there is worn the F out. it's old
Howz the wiring coming along? Ya coulda wired the Space Shuttle by now! JK
Here's my take on Optima battery's - they rock. Now, red top -vs- yellow top. Well, when I bought my red top it was cheaper than the yellow top and had a longer warranty. Red top for average use profile. Yellow top for deep cycle, i.e. run stereo with engine shut off while parked.
Yellow had higher price tag, shorter warranty, deep cycle.
I think the cells are exactly the same and they just put yellow plastic on the top of one and red on the other. They charge more and issue a shorter warranty to cover failures due to the nasty usage profile of the yellow top.
Not an uncommon practice - and I don't fault Optima a single itty bitty bit if that's what they do.
I'm good with the cheaper red top version.
