WA FS: Synapse Engineering 40mm Wastegate
  • Thread starter Thread starter Matts96HB
  • Replies Replies 43
  • Views Views 6K
About to send the invoice.
Both of those pieces you listed will work. I'd get the smaller one, personally.
Payment sent. The smaller seal contains some copper in it too. Correct? If you have a extra gasket and bolts to go with it, please thrown them in.
Thank you!!!
I'll search for an extra gasket, but I know for sure that I only have one set of bolts (the bolts holding my wastegate on right now :P )
I'll ship this out tomorrow after work.
Thanks. You never mentioned the springs. Does it come with the smaller spring or will I have to order it. Like I said, I need to set it at 5-7 psi only. Is this what you used it at?
I believe it has the smaller spring in it. I bought it a long time ago so its hard to be certain but I do know for a fact that I had the wastegate set to 9psi at one point, using only one vacuum port. So a lower boost pressure is possible with the installed spring.
