suspendedHatch
audio/security
You didn't read my post correctly.
I acknowledged that the wire colors are different. That much is clear to anyone that follows this thread. What I'm saying is that you can completely ignore the wire colors and look at the pins. You have the pins wired incorrectly, or at least it appears so if I compare the pins on my OBD0 distributor connector to yours.
Also, the chart doesn't help me with the two white wires because both of my white wires are the same size.
My OBD0 distributor plug connector came off a 89 Civic wagon AWD that has a D16A6 engine.
If you would like, I can post a picture of my plug connector. All the wire colors correspond to the chart and you can compare my pins to yours.
