Car dies at idle and at times no start
  • Thread starter Thread starter Jayamashey
  • Replies Replies 6
  • Views Views 5K
Jayamashey
'89 Civic SI with B16A2
- steady idle at 500 RPM
- timing is good and not gettting any codes
Car ran fine until 2 days. I was driving it and at a stop light it just died then I started it up again no problem.
Then today I went to start it and it wouldn't start. After waiting about 20 minutes it deciced to start but kept dying at or near idle and would want to start. I could only run it with the gas slightly pressed. After i got home it idled fine and didn't die.
Any idea's whats causing this?
Electrical?
maybe the altenator?
That doesn't explain the no-start after it dies. Plus battery has full charge. I was questioning if it could be fuel pump - but I don't feel fuel cutting out.
Plugs and wires are new. And since its at idle I don't think its the dizzy.
This problem is baffling me.
Turns out it was the ignitor chip - I luckily had one from an extra distributor.
