celerity should have waited a bit for this
  • Thread starter Thread starter jeffie7
  • Replies Replies 11
  • Views Views 2K
jeffie7
Wrong Whole!
VIP
He likes his bikes small. =)
Honda_CBR125R_2007_rouge_stgz
Engine Type Liquid-cooled single-cylinder four-stroke Displacement 124.7cc Bore & Stroke 58mm x 47.2mm Compression Ratio 11:1 Valve Train Chain-driven SOHC, 2 valves per cylinder Fuel Delivery PGM-FI fuel injection Transmission Six-speed Final Drive O-ring-sealed chain Front Suspension 31mm telescopic fork; 109mm (4.3 inches) travel Rear Suspension Single shock; 120mm (4.7 inches) travel Tires 80/90 - 17 front; 100/80 - 17 rear Brakes Front 276mm disc with dual-piston caliper; rear 220mm disc with single-piston caliper Seat Height 776mm (30.5 inches) Wheelbase 1,294mm (50.9 inches) Dry Weight 119 kg (262 pounds) Fuel Capacity 10 litres Colour Fireblade Red, Nighthawk Black, Hurricane White
.....my dirt bike has bigger tires than that....
hell the 250 even has bigger tires than that...
125cc... Wonder what the top speed is, and how long it takes to get there.
no doubt this bike makes the ninja look like poo, or atleast it shows just how outdated the 250/500 is.
Guessing not that far from the ninja, thats just a guess, basing it on the old motor used for the ninja and maybe a new motor for the honda? also the honda from these specs says its fuel injected so maybe its not too far off from the ninja 250.
I'll have to keep my eyes out for a review.
