D15Beater
HNFTuning
so let me get this straight, the first couple runs you had the tornado installed, and the third one you removed the intake and tornado all together, and lost power? gee i wonder why, it wasnt because you removed the tornado, its because you removed the intake.
So youre saying that no intake and a open throttle body will run worse? im just trying to learn bro and I appreciate the input. Can you describe what having the intake on there does. Velocity increase or what? I dont get it, neither did the guy running the dyno. His idea to remove the intake was to try and lean the engine out some, which it did but also made less power at a higher rpm as you can see above. im puzzled, really.
