DriverFX Racing Seat Never Installed! (no rails) - $120
4 15x6.5 4x100 Rota Slipstreams w/o tires - $300
Wheel1
Wheel2
Wheel3
Wheel4
PR3 Mugen Chipped Ecu - $150
EDM CRX Steering Wheel (Germany Origin) - $200
Set of 90-91 Crx Si seats (typical driver tear,pass rail only) - $150
D-series turbo manifold (ram horn style, ready for any flange/waste flange you want [will install those flanges]) - $750 (new)
EDM Crx wing - $215
Ground control coilovers eibach springs in the rear, skunk2s in the front, one of the skunks has a cut thru just over half of one spring (88-91 crx) - $185
Crx radiator w/ fan - $60
B16 stock cams - $50
MSD blaster coil (new) - $30
Neuspeed Rear lower tie bar (needs ends) Crx - $20
Neuspeed rear strut bar Crx - $150
Integra Cluster Bezel - $20
Tuner Toys oil feed tap for turbo or ls/vtec - $15
B16 crank - $70
B-series oil pan - $20
Moroso Blue Ignition Mystery Box - $45
B16 oem JDM 2-piece header - $Make Offer
B-series alt - $175
B16 stock bare block - $75
