Wet vs. dry depends on your fuel management system. In general, the wet is easier since fuel is added along with the nitrous, so you don't have to worry about adjusting the ECU. On the other hand, a dry system will work just as well as a wet system, if tuned properly(adjusting the ECU to compensate for fuel).
