I love black and milds. I love them even more when I ake the time to remove the cardboard.
Heres how you remove the cardboard. with the plastic wraper they have on them bite the very end of the plastic wraper off.
Then roll the B&M in the tube taking the tobbaco out. when you have the majority of the tobbaco out theres gonna be that bit left thats stuck down in the tip area.
Press roll the end of the tip around between your fingers and tap some of it out in to the plastic wrapper.
Then take some needel nose pliers and grab the carboard and pull it out but not to far that you take it all out.
Rip the cardboard off and take something like a screwdriver and push it back in to the tip area so yous till got your filter.
If you end up taking it all the way out then use a piece of the carboard and wrap it around a bic pin tube with the wrighting tip on still and push it back into the tip. Might want to use a safty pin to poke a coule holes in it as you might lose some suction when smoking.
Then tap the tobbaco back into the ciggar tube and lightly press the tobbaco into the ciggar tube but becarefull as youmight rip the paper.
Once you have it all back in, smoke it and enjoy a B&M without the cardboard paper crap.
But remember you may have to relight it once or twice as the carboard is what keeps it lit partly.
I do this to all my B&M and I love it. I will never smoke a B&M with the cardboard paper in it again.
