How To: Make your gauge cluster brighter and clearer.
  • Replies Replies 75
  • Views Views 52K
I know they do, i dont get why a bulb is pushing power to 2 more bulbs, but noone sells those little bulbs except for dealer probably cause i went around today and couldnt find them
OMG people. Do you not understand that the those are #194 bulbs?
The smaller ones are #74.
OSRAM SYLVANIA - Replacement Guide - Start
sylvania said:
1991 HONDA CRX
Low beam headlamp
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
9006LL Long Life Halogen Upgrade: Lasts one and a half times longer
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
1157
1157LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
1156
1156LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear turn signal
1156
Tail light
2057
2057LL Long Life Upgrade: Up to twice the life of the standard lamp
Stop light
2057
High mount stop light
921
921LL Long Life Upgrade: Up to twice the life of the standard lamp
License plate
168
Back up light
1156
Front sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear sidemarker
168
Dome light
DE3022
Step/Courtesy light
194
Trunk/Cargo area
DE3423
Instrument-general
194
74
Hi-beam indicator
74
Seat belt indicator
74
Brake warning
74
Directional signal indicator
74
Do you believe me NOW?
I never doubted you, I just asked what they were there for. I knew they were 194 bulbs, ive bought them many times for my truck
Also, not to be a dick but in the 89 civic, those instrument lights arent there lol
So i figured out that the bulb in the pic i have lights the gauges to. I took the 2 white ones out with the blue covers out and put green bulbs in. I now have green dash lights cause i took out the 2 tiny bulbs on top till i buy green ones for that.
What bulb is this for?
That bulb is for lighting up the numbers on the gauge faces and the two bulbs it connects to on the top are T1.5 bulbs.
You can find LED bulbs to replace the ones on top but it is hard to find the ones that are already in there unless u go straight to Honda or get them out of another gauge cluster.
great write up. i did it...changed it back thou. i thought this brightened up the numbers and stuff. this lights up the whole cluster. how do you get the back groung for the numbers brighter?
Not true. You can get those at pretty much any auto parts store. The trick would be finding the little gel covers that Honda puts over the bulbs.
But if you just want a replacement bulb, those are EASY to find. Just look it up in the lighting reference book like you would with any other light bulb on your car...
how many light up the back of the cluster? i think im gonna do this... red or green?
I had my cluster done up with red back lighting and blue front lighting and it looked pretty cool. I would say give green a try as it should be pretty cool as well.
well i took that diffuser and sanded the black off then buffed it to make the light go back through better and it looks pretty good red :D
I am on my way to do this right now, I want to replace it with LEDs. Are the numbers the same for the LED bulbs?
