Clutch popping noise?? Help Please
  • Thread starter Thread starter Harms Way
  • Replies Replies 3
  • Views Views 836
Harms Way
I have a 2000 Integra GSR with 68,000 miles on it. I have noticed that the clutch will make a popping noise when I put it into reverse and begin to engage the clutch as I back up slowly. It is almost like it pops each time the axle is spinning around. It doesn't do it when I put the car in 1st and engage the clutch as I move forward, only backwards so far.
What do you think it is?
Thanks in advance for any help.
does it do this when you turn sharp, left or right? could be a bad axle making the popping sound you hear..
Maybe missing some teeth on your Revers gear!
